Here's what i've got:
2003 Jetta 1.8T auto/tiptronic
Floor shifter tracks along the floor gear indications, however the instrument cluster doesn't match what the floor indicator does. For example, shift all the way forward and the floor indicator shows P, the cluster shows R. I have to put the key in, turn 1/4 and shift to "N" on the cluster to start the car. I can shift all the way forward to "R" on the cluster to shut off the car and remove the key.
It is not related to the "magnet" on the top of the shifter. this circuit board is completely unplugged and the symptoms remain. So, what drives the instrument cluster for gear position?
I have watched the you tube video on resetting the cable for a manual transmission, would this apply for an automatic?
Is there a lower magnet that i can't see? Does anyone have an exploded view of the shifter and cable to the transmission and any connections to the instrument cluster?
