Northern California's 034 Motorsport has announced the release of their Solid Adjustable Rear Sway Bar kit for Front Wheel Drive fifth and sixth generation Volkswagen Golf and Rabbit models.  Constructed from 25.4mm thick spring steel, the 034 Motorsport Adjustable Rear Sway Bar kit comes in at 215% to 290% stiffer than the stock bar depending on setting.
Check out the full Press Release below.
034Motorsport is proud to announce the availability of their Adjustable Solid Rear Sway Bar Kit for Front-Wheel Drive MkV & MkVI Volkswagen models, including the Golf, Jetta*, Rabbit, GTI, and GLI!
034motorsport-mk5-mk6-volkswagen-vw-gti-gli-fwd-rear-sway-bar-pr
While the MkV/MkVI chassis is very capable from the factory, it suffers from understeer that is inherent with front-wheel drive platforms and compounded by the miniscule stock rear sway bar. The 034Motorsport Adjustable Solid Rear Sway Bar is designed to address this shortcoming of the factory design, and complements 034Motorsport's extensive line of high-performance spherical suspension components available for the MkV/MkVI chassis.
Engineered to be the ultimate rear sway bar upgrade available, 034Motorsport's rear sway bar is manufactured from high-quality 25.4mm thick spring steel for maximum rigidity, and designed to combat understeer while reducing body roll under hard cornering. Combined with the sway bar's two-way adjustability, this design allows for an increase in the sway bar rate by 215% on the "Soft" setting and 290% on the "Firm" setting when compared to the stock rear sway bar. In addition, this sway bar is engineered to be used effectively with the stock front sway bar. No upgrade in the front is needed or required.With the stock front sway bar and upgraded 034Motorsport Solid Rear Sway Bar, body roll is virtually eliminated while turn in and off throttle oversteer are greatly improved.
034motorsport-solid-adjustable-rear-sway-bar-mk5-mk6-mkv-mkvi-volkswagen-golf-jetta-rabbit-gti-gli-8j-8p-audi-tt-a3-fwd-1
Every 034Motorsport Adjustable Solid Rear Sway Bar Kit includes a powdercoated rear sway bar, beautiful billet aluminum rear sway bar mounts with integrated grease fittings, graphite-impregnated urethane bushings, and new high-grade installation hardware. More information about this sway bar and related products can be found on the  034Motorsport website .
*Fits Volkswagen Jetta models equipped with independent rear suspension.
