1 - 20 of 177 Posts
Moderator
Discussion Starter · #11 · (Edited)
Update time
For background on my issue, post #640 is about where it starts
Making MK4's Great Again Thread
Cliff notes:
BDF ECU - 3.2 cam adaptable tune w/ deletes, LC and NLS
BJS engine and lamba harness
BDF cam bridge and adjusters
BDF cam phasers/sprockets
BDF upper timing cover and CPS’s
Check block 208/209 to confirm.
Reassemble.
Moderator
Discussion Starter · #12 · (Edited)
Goodies already installed, pictures to be added.
Engine:
BUB (Audi A3) 3.2
Techtonics Tuning 262 cams
42DD velocity intake
R32 manifolds and down pipes
Argon Addicts HFC
42DD catback no res
New NGK spark plugs
Timing chains replaced
New 24v specific radiator
VF trans, engine, and pendulum mounts
Trans:
O2Q (R32 Trans)
Diesel Geek sigma 6 shifter
Main shaft shim kit
Southbend stage 2 clutch with s/m flywheel
Solid bushings on linkage
Suspension/Steering:
Tyrol Sport solid subframe bushings
Tyrol Sport solid steering rack mount
R32 control arms
R32 spindles
R32 under axle style front sway
R32 Steering rack
Interior:
R32 Euro cluster
Moderator
Discussion Starter · #13 · (Edited)
Goodies to go on.
Brakes:
Brembo GT kit
Stoptech replacement rings
Hawk HPS 5.0 pads
SS lines
:pic:
Epytec rear adaptors for 280mm rotors and r32 rear calipers (retains OE ebrake)
Wheels:
19x8.5 LM147 BBS LMs
Suspension:
Airlift 3H
Performance fronts
SS5 rear w/ IDF brackets
IDF drop plates
Endo CT tank
Exhaust:
2.5” QTP cutout
Interior:
Climatronic
R32 dash
R32 steering wheel
GLX sunshade
Black W8 dome light
Black rear motion sensors
OEM navi
Rear Recaro armrest bench
Rear child booster bench
Exterior:
VXT Retro style HIDs
Bora R front
Bora R rear
4 door R32 skirts
Pzwo grille
Pzwo P1 mirrors
04 trunk, euro recess, welded blend
Headlight washers
Half cups
Speedwing
Moderator
Discussion Starter · #20 ·
Sent my ECU back to Ryan Horne (Eurocustoms) for some additional deletes. Once I get that back, I should be ready to run.
Since I’m running R program, and harness, the flapper needs written out. And I went ahead and deleted Evap because I got tired of trying to get all the right pieces (would’ve been easier to just of had a parts car, then I would have left it)
1 - 20 of 177 Posts
