1 - 5 of 5 Posts
2013 Beetle Turbo DSG | 2022 Tiguan SE 4Motion
K04 ftw. That being said, make sure the rest of your car is up to spec before you do upgrades. The first mod should always be maintenance (;
I have build a 2.0 L stroker with Intergraded Engineering Street cam, professionally ported head, new Supertech Valves and springs, Intergraded Engineering rods, Mahle Pistons (83mm bore) with upgraded pins, a 2.0 crank out or a 07 A3 (forged), arp main studs, head studs, I went with a stage 3 turbo from turbo concepts it is a very nice piece, upgraded exhaust manifold, a 02m with a wavetrac stage 2+ spec clutch and flywheel, Radium Engineering surge tank, all new -6 ptfe feed line and return, Snow performance direct port Meth, I forgot to mention a Intergraded Engineering Intake as well. I went with 1000cc Injectors because i want ot run e85 and i always build for the future as well I hope this turbo satisfies me, I really want a gtx3076? I will post up some build pictures and start a new build thread.
1 - 5 of 5 Posts
