Dash light come on yesterday. I know about the headlights and vents flaps. Just cant find why the EPC light came on? Any thoughts anyone?
Wednesday,16,April,2014,17:26:59:33598
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN: WVGMB77L07D019375 License Plate:
Mileage: 98250km-61049mi Repair Order:
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGMB77L07D019375 Mileage: 98250km/61049miles
Address 01: Engine Labels: None
Part No SW: 7L0 910 560 F HW: 7L0 907 560
Component: 4.2l V8/4V 0010
Revision: 75H03--- Serial number: VWX3Z0F6517348
Coding: 04210009590F0560
Shop #: WSC 31414 790 00001
VCID: 2E531CD2BA947B6E39B-515C
1 Fault Found:
001537 - Internal Control Module
P0601 - 001 - Memory Check Sum Error - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 98244 km
Time Indication: 0
Freeze Frame:
RPM: 1292 /min
Load: 19.6 %
Speed: 0.0 km/h
Temperature: 72.0°C
Temperature: 35.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 11.938 V
Readiness: 0010 0100
Address 02: Auto Trans Labels: 09D-927-750.lbl
Part No SW: 09D 927 750 CR HW: 09D 927 750 CR
Component: AL 750 6A 0941
Revision: 00H51000 Serial number:
Coding: 0004216
VCID: 800F126AD080BD1E1B7-515C
No fault code found.
Address 03: ABS Brakes Labels: 7L0-907-379-MK25.lbl
Part No: 7L0 907 379 G
Component: ESP ALLRAD MK25 0203
Coding: 0014594
VCID: 3D712B9E60F290F6B01-8068
1 Fault Found:
00778 - Steering Angle Sensor (G85)
000 - - - Intermittent
Address 05: Acc/Start Auth. Labels: None
Part No SW: 7L0 909 137 B HW: 5WK 485 17
Component: 29 Kessy 6840
Revision: 68406411 Serial number: VWX3Z0F6517348
Coding: 0147688
VCID: 326B08A2AEAC5F8E5D3-515C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
1 Fault Found:
01176 - Key
008 - Implausible Signal - Intermittent
Address 06: Seat Mem. Pass Labels: None
Part No: 7L0 959 760
Component: Sitzverstellung 0701
Shop #: WSC 00000 000 00000
VCID: F7FD79B6854EFAA62AD-5140
Address 08: Auto HVAC Labels: 7L6-907-044.clb
Part No: 7L6 907 044 AB
Component: CLIMAtronic 2+2 4325
Coding: 0020030
Shop #: WSC 01814 444 69312
VCID: 74E7CEBA143811BE8FF-515C
Subsystem 1 - Part No: 7L6 907 049 E
Component: CLIMAtronic FOND 0400
4 Faults Found:
00711 - Left Footwell Flap Positioning Motor (V108)
000 - -
Freeze Frame:
02379 - Positioning Motor for Left Side Vent (V299)
000 - -
Freeze Frame:
02508 - Temperature Sensor for Refrigerant (G454)
010 - Open or Short to Plus
Freeze Frame:
00445 - Loss of Refrigerant
015 - Cannot Be Tested at this Time
Freeze Frame:
Temperature: 52.0°C
RPM: 2656 /min
Absolute Pres.: 13.0 bar
Load: 60.0 %
Temperature: 32.0°C
Temperature: 28.0°C
Load: 32.4 %
Temperature: 46.0°C
Address 09: Cent. Elect. Labels: 7Lx-937-049-V1.clb
Part No: 7L6 937 049 M
Component: 3003
Coding: 0104671
VCID: 468344723224D32EE1B-5140
1 Fault Found:
00907 - Intervention load Management
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 H
Component: 05 Airbag 8.4E++H01 0562
Revision: BB38727 Serial number: 0009172=
Coding: 0012341
VCID: 285FEACA9B70255EF37-807D
Subsystem 1 - Part No: 7L0 959 339 C
Component: BF-Gewichtsens. 006 0008
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 H
Component: Lenksäulenmodul 3401
Coding: 0010032
VCID: 44875E7A0418E13EFFF-515C
Address 17: Instruments Labels: 7L6-920-xxx-7LA.lbl
Part No: 7L6 920 981 P
Component: KOMBIINSTRUMENT RB8 3211
Coding: 0007231
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
VCID: F0EF42AAE020AD9EEB7-5140
Address 1C: Position Sensing Labels: 7L6-919-879.lbl
Part No: 7L6 919 879 A
Component: JCI PathPoint 2200
VCID: 4581437E0F22D836E81-5140
Address 22: AWD Labels: None
Part No: 0AD 927 755 BE
Component: TRANSFERCASE 0119
VCID: 7F0D11962D7E42E6E2D-5140
Address 34: Level Control Labels: 7Lx-907-553-34.clb
Part No: 7L0 907 553 H
Component: LUFTFDR.-CDC- 3C3P1 3099
Coding: 0015521
VCID: 387F3A8A4FD0B5DE637-806D
1 Fault Found:
004 - No Signal/Communication - Intermittent
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzverstellung 0703
Address 37: Navigation Labels: 7L6-919-887-DVD.lbl
Part No: 7L6 919 887 M
Component: Navigation 0047
Coding: 0000101
VCID: 50AF622AC0600D9E4B7-5140
Address 46: Central Conv. Labels: 7L0-959-933.lbl
Part No: 7L0 959 933 H
Component: YM HSG 0400
Coding: 0000085
VCID: 4189576E1B0AF416D49-4B1A
Subsystem 1 - Part No: 7L0 959 701 H
Component: Tuersteuergeraet FS 0201
Subsystem 2 - Part No: 7L0 959 702 H
Component: Tuersteuergeraet BF 0201
Subsystem 3 - Part No: 7L0 959 703 D
Component: Tuersteuergeraet HL 0201
Subsystem 4 - Part No: 7L0 959 704 D
Component: Tuersteuergeraet HR 0201
1 Fault Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Address 47: Sound System Labels: 7Lx-035-4xx-47.lbl
Part No: 7L6 035 456
Component: 08K Audioverst. 0105
Subsystem 1 - Part No: 7L6 035 456
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 55: Xenon Range Labels: 7L6-907-357.lbl
Part No SW: 7L6 907 357 HW: 7L6 907 357
Component: AFS-Steuergeraet 0003
Revision: H09 Serial number:
Coding: 0000009
VCID: F8FF7A8A8F50F5DE237-80AD
Subsystem 1 - Part No: 7L6 941 329
Component: AFS-Lst.-Modul l X018
Coding: 00000034
Subsystem 2 - Part No: 7L6 941 330
Component: AFS-Lst.-Modul r X018
Coding: 00000034
3 Faults Found:
02628 - Sensor for Swivel Module Position; Right
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 3
Fault Frequency: 254
Reset counter: 225
Time Indication: 0
02235 - Stationary Cornering Lamp (Left) (M51)
011 - Open Circuit - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10101011
Fault Priority: 3
Fault Frequency: 2
Reset counter: 98
Time Indication: 0
02236 - Stationary Right Cornering Lamp (Right) (M52)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 163
Time Indication: 0
Address 56: Radio Labels: 7L6-035-186-DVD.lbl
Part No: 7L6 035 186 E
Component: Radio 0047
Coding: 0014062
VCID: 356133BE5FC248B6781-5140
Address 68: Wiper Electr. Labels: 7L0-955-119-V2.clb
Part No: 7L0 955 119 K
Component: Front Wiper 4027
Coding: 0000341
Shop #: WSC 31414 790 376833
VCID: 3C77269A7CE899FE87F-515C
Subsystem 2 - Part No: 1K0 955 559 AB Labels: 1K0-955-559-AF.CLB
Component: RLS 131006 020 0105
Coding: 00208933
Shop #: WSC 31414
Address 69: Trailer Labels: 7L0-907-383-1D2.lbl
Part No SW: 7L0 907 383 N HW: 7L0 907 383 N
Component: J345 Anhaenger 0080
Revision: 4A009002 Serial number: 00000134957823
Coding: 0016386
Shop #: WSC 00512 001 24584
VCID: 3F8D51966DFE82E6A2D-5140
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 7L6 907 441 HW: 7L6 907 441
Component: J772__Rearview 0051
Revision: 00H07000 Serial number: PA8 J670322
Coding: 0000101
VCID: F2EB48A2EE2C9F8E1D3-515C
Address 6D: Trunk Elect. Labels: None
Part No SW: 7L6 959 107 HW: 7L6 959 107
Component: J605 HECKKLAPPE 1110
Revision: --H05--- Serial number: --------005275
Coding: 0022110
VCID: F8FF7A8A8850F5DE237-515C
Address 6E: Ctrl Head Roof Labels: 7L6-919-044.lbl
Part No: 7L6 919 044 T
Component: DACHDISPLAY 0539
Revision: 00900539 Serial number: 2009289.07
VCID: 489F4A4A3830C55E137-515C
Address 76: Park Assist Labels: 3D0-919-283.lbl
Part No: 7L0 919 283 F
Component: 0E Einparkhilfe 1107
VCID: 39793F8E73DAACD69C9-515C
End ---------------------------------------------------------------------
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 98244 km
Time Indication: 0
Freeze Frame:
RPM: 1292 /min
Load: 19.6 %
Speed: 0.0 km/h
Temperature: 72.0°C
Temperature: 35.0°C
Voltage: 11.938 V
Coding: 0004216
Coding: 0014594
1 Fault Found:
Coding: 0147688
Component: ELV XXXX
1 Fault Found:
01176 - Key
Coding: 0020030
4 Faults Found:
000 - -
Freeze Frame:
000 - -
Freeze Frame:
Freeze Frame:
Freeze Frame:
Temperature: 52.0°C
RPM: 2656 /min
Load: 60.0 %
Temperature: 32.0°C
Temperature: 28.0°C
Load: 32.4 %
Temperature: 46.0°C
Component: 3003
Coding: 0104671
1 Fault Found:
Coding: 0012341
Coding: 0010032
Coding: 0007231
Coding: 0000006
Coding: 0015521
1 Fault Found:
Coding: 0000101
Coding: 0000085
1 Fault Found:
No Faults Found
Coding: 0000009
Coding: 00000034
Coding: 00000034
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 225
Time Indication: 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 98
Time Indication: 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 163
Time Indication: 0
Coding: 0014062
Coding: 0000341
Coding: 00208933
Shop #: WSC 31414
Coding: 0016386
Coding: 0000101
Coding: 0022110
