Woah, which bulb? I’ve had both headlight assemblies out without removing the wheels, you just need to turn them lock to lock to get the fender liners loosened. The hardest part was getting to the bolt behind the washer reservoir, had to jam some chewing gum into a socket to hold the bolt while reaching in there.All this to change a bulb
Thanks for totally destroying what little motivation I had to do my headlight bulbs too 🤣![]()
All this to change a bulb.
Sent from my iPhone using Tapatalk![]()
Try this https://www.autobytel.com/volkswagen/passat/2007/configurator/So the CC seats must be part of the Sport package? I haven't seen much original documentation but I knew that some of the B6 cars got the CC seats. Which is funny because I've seen CC cars with V-tex inside, which I never thought they did and I've seen B6 cars with the leather CC seats.
If someone could point me to some resource where all the B6 stuff is known....options, packages etc that would be great. I have a 2009 brochure but it doesn't tell me too much.
Also, I had thought that wagons with the rear door roller blinds got different door cards than sedans with the blinds, just based on what I'd seen in pictures (not very good pictures) but it looks like in your pics that the cards are the same even though the roller blinds will be different because of the roofline.
Did the roller blinds become standard by 2009? I think most every car I've seen that was 2009 / 10 had the door roller blinds.
Any info appreciated
Steve
Off course the hardest one. passenger side. Had the car on jack stands so I can get to the bottom screws. I got something for those pesky bolts my trusty two footWoah, which bulb? I’ve had both headlight assemblies out without removing the wheels, you just need to turn them lock to lock to get the fender liners loosened. The hardest part was getting to the bolt behind the washer reservoir, had to jam some chewing gum into a socket to hold the bolt while reaching in there.
Totally worth it! Is like new headlights. Can’t believe difference. It had Philips bulbs went with hella d1s 5000k 35w.Thanks for totally destroying what little motivation I had to do my headlight bulbs too![]()
Yes, I've seen that before, and it at least outlines a little, but it doesn't say what's (really) standard equipment nor does it mention Climatronic or really anything non-package except for the wheels and audio. And there were more wheels available in 2007 than just standard Catalunya and the two options they list....and where's the 18" wheels? And there's no mention of MT either. I'm surprised they listed the Dynaudio at all...Try this https://www.autobytel.com/volkswagen/passat/2007/configurator/
Thanks for all that info,This is all by memory, but IIRC:
- in 2006 the VR6 was available in Base, Lux or Sport 1; Sport 2 was an option in 2007, and in 2008 they were all Sport 2.
- Base, Lux, and Sport 1 came with 17" wheels; Sport 2 added 18" wheels and the sport suspension (stiffer springs, bigger sway bars, and 1/2" lower)
- Sport 1 came with the sport seats, 3-spoke steering wheel with shifting paddles, and aluminum trim. Sport 2 had all that plus the wheels and suspension upgrades.
- Lux and Sport 1 added Climatronic, real leather, heated seats, and sunroof (some of these might have been stand-alone in earlier model years)
- Dynaudio, Nav, and Automatic Cruise Control were stand-alone options
- In early 2008s everything was standard except for Nav and auto cruise
- Dynaudio was deleted in late 2008 due to parts availability issues and a credit was given instead
That's the general idea!
Other way around.So the CC seats must be part of the Sport package? I haven't seen much original documentation but I knew that some of the B6 cars got the CC seats. Which is funny because I've seen CC cars with V-tex inside, which I never thought they did and I've seen B6 cars with the leather CC seats.
Those would be 2.0T cars, I was just talking about the 3.6 trim levels. Yeah, on the 2.0T you could get 16" alloys or steel, and there was the Value Edition and Wolfsburg edition and Base and Turbo etc. etc. but I'm not familiar with them.Thanks for all that info,
Are you sure that Base, Lux, and Sport 1 came with 17" wheels? I've seen lots of cars with the 16" alloys and even some with steel wheels and hubcaps. I think you must mean Lux and Sport 1, and not Base?
Where does the 'value edition' fit in with this?
Oh...ok, didn't realize there was such a divergence between 4 and 6 cylinder cars.Those would be 2.0T cars, I was just talking about the 3.6 trim levels. Yeah, on the 2.0T you could get 16" alloys or steel, and there was the Value Edition and Wolfsburg edition and Base and Turbo etc. etc. but I'm not familiar with them.
I don't think I've ever seen a CC VR Exec in person, there aren't many of those floating around this area and the ones I do see typically are 2.0t cars.Other way around.
The higher trim CC's (think VR6 Executive) received the same leather Sport Seats that the B6 Sport Package had, as the B6 Passat was before the CC.
The lower trim CC's had the (standard) V-tex seats, and were styled different & nothing like the B6 seats.
Thanks for posting that!Emich VW has all of the ordering guides on their website going back to 2007 if you want to see the exact package details.
Free Volkswagen Order Guides Download for VW Car and SUV Models
VW order guides from 2007, 2008, 2009, 2010, 2011, 2012, 2013, 2014, 2015, 2016, 2017, 2018, 2019, 2020, 2021. Trims, colors, standard & optional equipmentwww.emichvw.com
-_/
Those are very informative but so much better when formatted properly in list form. The list of separate options however seems to be a little thin.Emich VW has all of the ordering guides on their website going back to 2007 if you want to see the exact package details.
-_/
Anyone know if the automatic liftgate was standard equipment on 2.0t wagons in 2007?
Thanks
Steve
