1 - 4 of 4 Posts
At my whits end now with it ... 08 R32 poor starting when hot or cold. Turns over for ages before it catches after its started it lovely quite smooth and plenty of go. Gets to tempreture fine and holds 90 all the time everything is working as it should. You can hear the pump prime when u open the drivers door. So far ive replaced ....
Fuel pump and filter
Crank sensor
Spark plugs
Both front lambda sensors ££££££
There is nothing coming up with my Autel MK 808 any ideas would be great ....
wrong forum... but how about the starter itself????
Sent via Carrier Pigeon
Also sounds like it could have a problem holding or getting fuel pressure at the rail? FPR?
Discussion Starter · #4 ·
Yes it sounds like that that why i changed the pump. Its turning over fast enough just not catching .... need to see if i can see fuel rail pressure when turning it over ....
1 - 4 of 4 Posts
