Just curious... does anyone know where the ATF temperature sensor is located on the ribbon cable? Is it inside the connector housing itself where it seals with the transmission case?
The reason I ask is that I'm installing a new upgraded cable with actual wires instead of the fragile ribbon cable, and I've seen reported several places that the temp sensor is integrated into the ribbon cable, but I don't see where that may be on the new harness. I'd like to confirm from someone that has installed the updated harness with the individual wires that the temp sensor is accommodated in it.
