09A reverse gear suddenly problem IN HALF SOLVED
Happy New Year!
Excuse me fo my bad language, but I'm from Bulgaria /another side of the Earth/.
I have VW Golf 4 1.9 TDI PD with Tiptronic gearbox /09A/.
The car is 7 years old with 170K kilometers /~100K miles/ on the clock.
Several days ago, when I go out my work, I can't engage my reverse gear.
The selector lever moves into reverse, on the dashboard "R" appear, but the gear does not engage.
The car drives fine when going forward.
I have diagnostic software /VAG-COM 311.2/. The diagnostic shows next fault:
Address 02 -----------------------------
Controller: 09A 927 750 H A
Component: G5 Getriebe 09A 0138
1 Fault Found:
00281 - Vehicle Speed Sensor (G68)
03-10 - No Signal - Intermittent
I erased the fault. After 200 kilometers I diagnostic again, but does not show any fault.
First of all, I intend to check ATF level, but I can't measure the ATF temperature.
VAG-COM shows only:
Sorry, for stupid question:
Previous day, before this trouble situation, I chnged the engine oil in the little private garage.
Can the fitter make a mistake for a plug at a moment, and to drain out for instance 1/2 litre of ATF?
Any help/suggestions greatly appreciated.
Best regards!
Conko Noykov
Modified by Noykov at 7:42 AM 1-25-2009
Modified by Noykov at 7:45 AM 1-25-2009
Happy New Year!
1 Fault Found:
VAG-COM shows only:
Best regards!
Conko Noykov
