I have a ****ting issue when it's cold. Doesn't go to 1st or 2nd. I had to wait a few minutes. LaSt wednesday, I started the work to replace the solenoids, all 9 of them and finished this morning. The job in itself isn't bad at all. Just takes a lot of time. I had to do a couple of things though while the front bumper is out, including the front metal frame. I had to replace my coolant ball and the radiator temperature switch due to overheating. I only lost around 1 quart of coolant. I changed my engine oil too.
I definitely recommend removing the battery and anything that is on the way including the bumper, metal frame. You need enough room to be able to do it right. Take it slow. I tested it this morning and all gear works. I'll find out in a day or too when it becomes very cold outside.
