i would describe it as if driving a manual car and reving high in 2nd gear and then shifting into 4th... skipping 3rd gear. thats how it feels but it doesnt actually skip any gears, it still goes through all 5 gears but the problem only occurs when going from 2nd to 3rd gear. Any thoughts on what might be causing the problem since its only effecting one shift....shifting for every other gear is fine, except from 2nd to 3rd.
i scanned it with ross-tech and got a 00652 which states the following:
00652 - Gear Monitoring: Implausible Signal
Possible Causes
Automatic Transmission Fluid (ATF) Level not OK
Vehicle Speed Sensor (G68) dirty/faulty
Impulse Wheel dirty or Installation faulty
Gearbox Speed Sensor (G38) dirty/faulty
Multi-Function Switch (F125) faulty (but not detected)
Clutch or Valve Body faulty
Automatic Transmission Fluid (ATF) Pump faulty
Possible Solutions
Check Automatic Transmission Fluid (ATF) Level
Check/Clean/Replace Vehicle Speed Sensor (G68)
Check/Clean/Replace Gearbox Speed Sensor (G38)
Check/Replace Multi-Function Switch (F125)
Check/Replace Clutch and/or Valve Body
Special Notes
The ratio of engine speed to gearbox output speed in the currently engaged gear is implausible.
Slip rpm with torque converter lock-up clutch disengaged must be greater than stall speed.
thanks
Possible Causes
Possible Solutions
Special Notes
thanks
