1 - 6 of 6 Posts
My 2013 TTS is stock, except for brake pads and fluid, and the 034Motorsports aluminum dogbone mount inert. I'm considering the following modifications combinations during 2016:
1. Stage 1 APR and H&R RSB...aprox $850
2. Stage 1+APR using IE's HPFP...approx $1,100. I'll build the pump.
3. Stage 1 APR and stage 1 DSG tunes...approx. $1,100
4. APR DP and H&R RSB...approx $1,150 and I'll do ECU and HPFP at a later date to make it stage 2+ with APR.
I'll probably get the H&R bar regardless at some point, but for those of you who have experience with modifying the TTS, which option would you do and why? Or maybe some other combo.
The order to which I did things...
1. Software
2. Swaybar, torque mount insert, HPFP
3. Turbo back exhaust
4. DSG software
If I were to do it again. I would do it in the exact same order.
Stock to 1, 1 to 1+, and 1+ to 2+. You could feel the jump every time.
Also if you wanted a extra HPFP I have my stock one that I am not going to use.
1. Springs and bars.....to tighten up the suspension....makes a huge difference......then save a few bucks and do you APR stuff. TTS already has the bigger brakes......my two cents.
why apr and not giac or um?
Local VW/Audi specialist, HSTuning is 10min away and they do APR. I want the support if any issues arise.
I have a 2.0 TSFI with a KO4 kit and Miltek quad exhaust (therefore essentially a TTS) with all your proposed mods.
1. For performance the tune is by far the most bang for the buck - but I would also absolutely get the matching DSG tune. Drive mode is now great for a little pep around town (instead of just being sluggish and lifeless) and Sport for when you want to have fun - really transformed the DSG for me.
2. For handling, absolutely the rear ASB (set to soft) and I would suggested MSS rear Sport springs (I have an extra set at a good price if you are interested)
IMHO these are all that's really needed unless you've got the modding disease (unfortunately I have a terminal case and am beyond help).
You don't need exhaust modifications until you go to Stage 2 or beyond (definitely the slippery slope) and only need a HPFP if required by the tune.
1 - 6 of 6 Posts
