Hi all
Just wondering if I could get some opinion/help from this group.
I have 1.4 Tsi EA111 Twincharger 160ps/118kw (yr 2011)...which has a problem of lumpy/shakey idle during cold start (no matter morning/evening/day....but occurs when the car has been resting for more than 12 hours).
This lumpy/shaky idle is occur only during the first 45-60seconds warm-up (during 45-60sec...as usual rpm goes higher to about 1250-1300)....after 45-60s warmup comepletes, it will go back to normal idle (no lumpy & no shaky) 700-750 without AC on.
I have changed all engine & transmission & dogbone mounts with OEM torque spec about 4 months ago.
Oh 1 thing I noted about this....eventhough this lumpy/shakey idle will go away after this cycle completes & rpm drop to normal idle 700-750.......you can always interrupt it.
Means when it's lumpy/shakey...if I turn off the engine before 45-60s warm up complete & restart the engine again.....it will not be lumpy/shakey (or at least will be much better).
The second problem that occurs in the last 3 weeks is misfire only at cyl1....during idle (at any time) if AC is turned OFF.
Misfire's count & second's count almost the same....(can be as high as 40-60 misses in 60sec).
Then it will trigger P0301 without CEL.
This cyl1 misfire will sometimes stop....then reset 0....then start again after some minutes.....it will always be like that as long as I have not turn ON the AC.
Once I turn on the air condition......no more misfires on cyl1 during idle (with AC on...rpm will go slightly higher from 700-750 to 850-900).
Tried swapping coils around & changed new plug on cyl1....misfire still stay at cyl1 (with AC off)
I uses 06E905115E red coils & BKR6EIX gapped to 0.75mm
I am hoping to maybe there are some tips/experiences I can get from anybody.
Many thanks
Regards
Kent
Many thanks
Regards
Kent
