Seems like not too many people here in the US are tinkering on the old 1.6 NA diesels out there, but I thought I might hit that one Jedi Master out there who might lend some insight.
I've got a 1984 Rabbit 1.6 NA with a 5 speed manual. Currently 169,000 miles. I recently tested the compression (cold) and it was about 390-400 on all 4. Admittedly a bit low by Bently specs, but still decent.
Two months ago I changed all the glow plugs with Bosch plugs. The glow system works great.
Here's my problems:
1) The Timing advance lever (i.e. choke lever) does not do a damned thing. The IP leaks a tad, especially around the choke lever, but not enough yet to warrant a rebuild/reseal just yet. I just checked the IP timing last week (originally it was about .88 mm, so I bumped it up to the Bently recommended .95 mm for a 1984 model without AC).
While I had the dial indicator in the pump, I pulled the choke lever just for gits and shiggles to confirm that it was advancing the timing. Sure enough, the dial indicator (set at .95 at TDC) moved up to about 1.30 mm. Looks like it's doing it's job, it's just not having an effect on vehicle idle or smooth running on cold startups. Any thoughts on why that is???
2) The car seems to be low on power. Obviously, this may be due to the less-than-ideal compression, but I reckon it may have more to do with the timing pump.
As noted, I just re-timed the pump. Before that, I've been having problems with leaking injector lines. It seems like no matter what I do, the lines seemed to find a way to leak no matter what I did. I've loosened and reset the metal lines dozens of times, and I replaced the rubber lines at least twice in the past year. I'm not running biodiesel, so that's not the cause. It seems like there may be too MUCH pressure coming out of the IP.
This last time, the #4 injector line was leaking pretty bad after a long trip to Birmingham (from Nashville). I was cranking along at about 80 MPH for about 2 hrs. In fact, it seems that the lines like to leak after I run along at speeds over 80 for long times. Not sure why that may be...
Anyway, I'm not sure what the lines are doing now since I cleaned and retorqued. But, as a precaution, I changed the injectors in case one (or more) was (were) clogged.
After all this, there has been no appreciable difference in performance.
We'll watch that tale, but in regards to the low power: how far has anyone advanced their IP timing for max power without adverse effects?? I know the book says 1.00 MM +/- 0.02, but I'd like to push the envelope if I can. It seems like years back, I bought a Rabbit that smoked like biyotch, but ran like a raped ape. I reckon that had to do with IP timing. I seem to remember it being WAY advanced. The car accelerated like a gasser and still got 45+ MPG.
Anyway, thoughts on the issue are appreciated, epecially from our friends north of the border who seem to have an un-tapped resource of knowledge on th 1.6 NA.
Here's my problems:
