I have an 85 MK2 golf with a 1.6D with 200k miles on it (assuming original but may have a newish head) and a 82' pickup with the same engine (~82k from an 82 jetta and driven on the pickup for 80k) and same 5 speed trans. In an attempt to figure out why the pick up is so much louder in the cab than the MK2, I did a lot of MLV/CCF/foil backed vinyl deadening and replace/realigned the driver/pass/rear trans mounts. All of this made marginal improvement to in cab vibrations and loundess. Vibrations decrease when in 4th or 5th or high rpm as it does with noise, but still very loud when compared to the mk2 golf. Does anyone have an explanation for majority of this harness difference between the two?
In addition, the MK2 golf accelerates much faster throughout the range of gear/speeds. I can hit 65mph easily even just in 3rd on a flat road and have topped out at 90mph on a cold day but rollin major coal (I know bad for the engine temps but I wanted to find out). On the pickup I can hit 75 eventually but I usually top out at 70mph and its a fight even on a cold day without black smoke. Could the gearing ratios be different?
I noticed that the IP on the golf has yellow makers marks on each nut that holds it together as if one was trying to clock each nut back after opening it up. Is this a sign that it was rebuild with some upgrades? PO of the pickup (friend of a friend that I trust the word of) rebuilt the IP on it at some point but doesn't remember how long ago.
Both cars have no AC.
Thanks for any input/insights
