http://forums.vwvortex.com/zerothread?id=1693335
look at the difference the dyno dynamics made. much much lower than than the dynojet or dynapack. the dyno dynamics is the same dyno gt300318 used. look how much lower it is then a dynojet or anythign esle. and, if you want, take a look a Vishnutuning.com. they explain it there. i believe they know a little more than you ever will. if you can read, you might be able to see where they are gettin the numbers from.
so, that just shows that the 215 is highly possible. but def. not 182.
