1.8T 2001 vs 2002
612 Views 9 Replies 8 Participants Last post by  RVs021.8T
Why is there such a horsepower difference?
2001 = 150
2002 = 180
Whats the difference with the engine?
1 - 10 of 10 Posts
Re: 1.8T 2001 vs 2002 (MKvw)
Nothing. Just reprogramed ECU. Just like when you get a chip, no engine mod, just reprogramming.
Is that a fact? I am thinking about buying a 2001 Golf and want to be sure.
Chipped they will be almost exactly the same. i think 210/215 hp .
I have heard that the factory exhaust (downpipe) on the 2002 is a little less restrictive. There was also a rumor that the cams were slightly different. Another rumor is that the 2002's have a different compressor wheel on the turbo. I dont know if any of this is true, just sharing what I have heard/read. Chipped, both cars will put out similar peak hp, but I think the 2002 puts out more torque.
quote:[HR][/HR]Why is there such a horsepower difference?
2001 = 150
2002 = 180
[HR][/HR]​
WOW. If I had a penny for every time someone asks this i wouldn't be driving a GTi right now....
Re: 1.8T 2001 vs 2002 (SlvrBllt)
I have read also that the turbo was using parts of the KO4.
J-F
'-2 is a completely different engine than an '01. You cannot chip the '01 and get the same performance of a similarly chipped '02. Exhaust and new camshafts acount for about 20HP. In a nutshell, buy an '02 1.8T and forget the chip altogether.
Re: 1.8T 2001 vs 2002 (Jetta_J)
It's no rumor: the turbo is different, you get variable cam timing(which later '01's had) and different software on the '02's.
Re: 1.8T 2001 vs 2002 (fitzpb)
quote:[HR][/HR]'-2 is a completely different engine than an '01. You cannot chip the '01 and get the same performance of a similarly chipped '02. Exhaust and new camshafts acount for about 20HP. In a nutshell, buy an '02 1.8T and forget the chip altogether.[HR][/HR]​
WRONG, they are basically the exact same when chipped,and at stock there isnt a true 30 hp difference its really only about 10hp check this same thread in the 1.8T forum. Its explained better there. AWW and AWP give the same chipped numbers.
[Modified by RVs021.8T, 3:00 AM 2-14-2002]
1 - 10 of 10 Posts
