1 - 20 of 50 Posts
I have been checking out the archives and the postings on engine codes so as to put everything onto a spreadsheet.
So far I have 26 different engine codes and the different things I'm noting are the following:
BHP rating
Compression ratio
Vehicle fitment
Date used
Cast or Forged crank
Head port size
VVT or not VVT
Internal or External Water pump block
Turbo used
Cable throttle or Fly by wire
Injector size.
If anyone has this info on any of the 1.8 20V engines, please post it here and I'll add it to the spreadsheet. I don't mind if things are repeated... it means that I got it right
If anyone thinks I should include anything else in the spreadsheet, please put your ideas here too..
Thanks all
Mike Ghia
Banned
Re: 1.8t 20v Engine codes... I'm making a spreadsheet (Michael Ghia)
Great idea. I could give you all the info on the basic three in the US but I'm guessing you have it all already. Let me know if not and I'll post it here.
In Brazil our Golfs and Audi A3s use the AUQ code. Its a 180cv engine like yours AWP. The difference is the ECU.
Your saying you have 26 engine codes for the 1.8T alone.
WOW
And these are from engines in countries all of over the world?
Quite the task there. I wish I could help. I have a filing cabinet full of technical data on pre 1997 vehicles.
I doubt VW even has a sheet with that info for all 26 variations from all countries.
Good luck
Slickfisher
Re: 1.8t 20v Engine codes... I'm making a spreadsheet (slickfisher)
Ok, I've just gone through all the Forums and websites and most importantly Etka so find out the info.
I need info on all of the 26 engines so anything you have... please send me.
The engines I have no info on at all are AMU, ATC and ATW. I think these are US code engines which don't exist in UK.
Cheers all.
MG
AMU= US 225TT Engine made in Mexico?
APX= euro 225TT engine brother to S3 210 APY engine.
BAM= later euro 225TT engine brother to S3 210 AMK engine.
Let see that database so we could comment on it.
Discussion Starter · #7 ·
Re: 1.8t 20v Engine codes... I'm making a spreadsheet (Mad Mel)
Ok, Thanks for that....
Codes now up to 36!
I managed to find a back door into Sun Micro systems internet info pages.... wow lots of engine numbers...
Codes I now have no info on are:
ATC
ATW
AWL
ARZ
BEX
AYN
AUG
Weird thing about ARZ is that Etka keeps trying to tell me its a V5!!
MG
Will post the spreadsheet in a bit... want to get it a little more complete yet.
Discussion Starter · #8 ·
I'm also needing info on all engines as to which had cast and forged cranks..
which had small and large port heads,
what turbo's they were fitted with
what size injectors they were fitted with.
Thanks
MG
Re: (Michael Ghia)
Don't know if Bora was ever fitted with an AUQ engine, since there are no turbo Boras in Brazil. We only have the 2.0 NA made in Mexico.
Strange thing, all American Golfs are made in Brazil, but the Boras are made in Mexico.
BFB 163 hp 07/02 A4
VER 150 sharan
ARK 150 7/98-7/99 A4
1/99-5/99 A6
ANB 150 1/99-8/00 Passat
5/99-6/00 A4
1/99-5/01 a6
AWD 150 5/99 jetta
AVC 150 7/99-10/00 Beetle
AWC 150 4/00 Sharan
BEX 190 11/02 A4
BEK 180 6/01 jetta
trottle body at cil 1 or 4 2/3
gearbox code
Quote, originally posted by Michael Ghia »
heheh.. you mean drive by wire right? ive never seen a dub flying before
Re: (HPR)
We have all data a school. I will check out the AWW,AWD,AWP and maybe some others I will post compression ratio's and all the sheeet you need. http://****************.com/smile/emthup.gif
There are V5 Volkswagen engines, they're called the VR5. Shouldn't show up as a 1.8L 20v engine tho
Re: (O2VW1.8T)
Quote, originally posted by O2VW1.8T »
we have all data at work, and i have all data on line.. i dont think all data gives cr on the 1,8t at all. all data is kinda lacking on anything but the basics these days.
Re: (vtecwrecker)
I dont see ATW on there. 2000 a4's and passats. k03, non vvt, dbw, 150 hp
1 - 20 of 50 Posts
