Re: 1.8T Boost Problem: What N75 do I need??? H valve=Turbo proble ... (JettMobberGli)
Quote, originally posted by JettMobberGli » |
I do have the stock one to put back in, its just a pain with those one time use clips! |
The point during the install was to remove the "one-time" hose clamps and place on standard adjustable worm-screw ones.
I did have it professionally installed, soo Im pretty sure it is done right. |
That's ok; but did you verify all connections?
its just when I really step on it....the wastegate on the turbo is flapping like crazy so the turbo is sooo sparatic... |
The "surging" you're feeling is more common with the "H" version.
Have you scanned the car with a VAG-COM to see if there are any fault codes?
Have you data-logged the requested vs. actual boost readings?
- Erik
