1 - 5 of 5 Posts
It's when you move the lever forward and back between 1&3 and 2&4. I noticed a bolt on top the tranny where the shifter connects was loose so I tightened it, which improved the feel a bit, but there is still a big dead spot. Is there an easy fix, or do I have to realign the whole thing? Thanks,
Discussion Starter · #2 ·
Re: 1" dead spot in shifter...how to fix? (FatSean)
Well I just cranked down on the bolt, and the shifter is tight again. But it just 'popped' when I hit the gas hard and loosened up again. Is there some wearable part I have to replace? Bently sez nothing.
1 - 5 of 5 Posts
