120block with gnuplot
485 Views 0 Replies 1 Participant Last post by  TurboZen
3
I did this with gnuplot. green=hp and red=torque does my math look right?
This is the command I used for gnuplot using datafile 120run3.txt:
plot 'c:\vag-com\logs\120run3.txt' using 2
$4*0.738) ',%lf,%lf,%lf,%lf,%lf' with linespoints,'c:\vag-com\logs\120run3.txt' using 2
(($4*0.738)*$2)/5252) ',%lf,%lf,%lf,%lf,%lf' with linespoints
Anybody care to check over my math?
Edit: Replace sad faces with the correct characters, I can't stop the madness
See less See more
1 - 1 of 1 Posts
1 - 1 of 1 Posts
