1 - 2 of 2 Posts
Discussion Starter #1
I'm planning to buy a set of 15mm spacers from someone locally. He's running them on RC's. Am I right to say that the bolts he's using is ball?
I have ASA AR2s, and I know I'm running conical bolts. So will that set be a waste of my money since the bolts won't work with my wheels?
Also can I still use a wheel lock bolt that's shorter with the 15mm spacer?
Re: 15mm spacer bolts? (VeeDub_6)
You will need extended cone seat bolts, which sell for about $2 a piece from distributors.
You will not be able to use the short keyed bolt.
1 - 2 of 2 Posts
