1 - 20 of 23 Posts
I would have searched (I did manually search through 13 pages before giving up) but since the search is down.... Anyways, I'm looking for what might be needed to run an ABA block with 16v head. Also, how easy is it to retain the serp. belt setup? And what's the compression on a setup like this using factory parts. Thanks.
Re: 16v ABA info wanted (Electron Man)
Well, ABF is the Euro 2.0-16 where ABA is the US tall block that many have converted over to a 16v by swappin on a head. So searching for ABF won't give you any info on that swap.
It is possible to put a 16v head on an ABA bottom end and it will run with out interference problems. Whether or not it a smart thing to do is the unanswered question.
[Modified by 130_R, 9:27 AM 2-16-2002]
I bought the Kent belt - ES $53.50 I am running the numbers though because that's a rip-off!! It's a stock belt in Europe! We just don't know the VW part number to order it from. There's no way that a belt that's only 1.5" longer costs 4x a stock belt.
The other solution is to run the 8v pulleys and buy a standard Gates belt which I have the PN for! Relatively minor mod work on the 16v cam pulley only - if you have an ABA bottom.
· Banned
Re: 16v ABA info wanted (OhioBenz)
quote:[HR][/HR]...look at the stock HP it makes compared to "our" version.[HR][/HR]​
When you say "our" I'm assuming you mean the 9A code engine (2L 16V).
Thanks for the info. on the Kent belt.
If ABA (w/16V head) compression is higher than ABF (using "correct" pistons), then the timing advance maps in the ABA ECU may need revision. Maybe that's what he's referring to?
[Modified by Electron Man, 3:38 PM 2-15-2002]
quote:[HR][/HR]I bought the Kent belt - ES $53.50 I am running the numbers though because that's a rip-off!! It's a stock belt in Europe! We just don't know the VW part number to order it from. There's no way that a belt that's only 1.5" longer costs 4x a stock belt.
The other solution is to run the 8v pulleys and buy a standard Gates belt which I have the PN for! Relatively minor mod work on the 16v cam pulley only - if you have an ABA bottom.[HR][/HR]​
The part # is... 048 109 119 G
if you can get this belt let us know
The ABA-16v combo has low compression because of the dished ABA pistons. The ABF setup has pistons that are the same configuration as the 9A except for the compression height and pin diameters are the same as ABA. ABA has a 30.9mm CH and a 21mm pin, 9A has a 30.2mm CH and a 20mm wrist pin. Hence the need for either custom pistons or modded rod ends (my choice)
Thanks for the VW number, I have had no luck running the number that was printed on the belt. My local little parts guy would love to be a US stocker of reasonably priced ABF belts
Re: 16v ABA info wanted (killa)
quote:[HR][/HR]Haha,i just finished the swap, i'm waitin for my damn brother to get home so we can pick her up and throw her into the engine bay, straight forward procedure.[HR][/HR]​
Hmmm, that contributed a lot of helpful information for the questions asked.
quote:[HR][/HR]OK, enlighten me as to why it wouldn't be the smart thing to do? That's exactly what I thought the Euro ABF was - look at the stock HP it makes compared to "our" version.[HR][/HR]​
I'm not trying to enlighten anyone but myself. I just put the finishing touches on a 16v Turbo ABA block for a friend and the compression numbers we got were not promising. In our case we have compression numbers that are around 7.9/1 compression ratio. Knowing that the guys who make 550 hp out of a 2 liter 16v engine are putting out around 9.5/1 compression ratio with a very large turbo attached makes us wonder if if we are a bit low.
All I ment by the statement was that the ABA/16v combo's are a bit of an unknown quantity at the moment, that's all. Until people start getting some hp numbers and comapring them, we don't know what this combination is capable of. Whether or not going down the path of the ABA/16v is the better choice compared to custom pistons with more compression, no one has real numbers to compare.
Re: 16v ABA info wanted (130_R)
OK, I understand the CR might not have been impressive, but my basic approach is that the block/bottom end construction combo with a 16v head is on of the best 4cyl combos available to us - with a whole range of fueling options. Choice of pistons is dictated by your desired outcome. If you just want to make a simple bolt-on/in swap, then maybe that's not for you. If you are looking to build a very sturdy 4cyl engine that can handle boost or high CR, then I think it is.
Re: 16v ABA info wanted (art.clemens)
It's not the actual cost because you are right - it is insignificant in the total scheme of things, it is simply the principle of charging more than double for an item - just because you can.
1 - 20 of 23 Posts
