Re: 16v Cabby - how hard? (itschuck2c)
Quote, originally posted by itschuck2c » |
But what we need is a bit more info of what is involved in this swap..
I got a 91 cabby with the digifant..so do i need pluck certain wire harnesses, or is it bolt up plug in and drive car.. anything is do-able but there is nothing worse then hitting a brick wall in the middle of a modification. |
A 91 Digi2 Cabby.. going to 16v requires scirocco 16v exh. manifold and downpipe, a fuel rail and fuel pressure regulator adapter, of which several companies make them, BBM is my choice, and new digifant injector cups with injector seals (very cheap @ dealer)..
Digifant runs a PL or 9A 16v just fine.. you'd be quite surprised at the power gained.. In a nutshell, swap motors, swap exh. mani/downpipe, use the injectors from the digi motor, remove the brass injector cups from the 16v head, install the new ones, replace the o-rings on the injectors, relocate your temp switches, then fire that bad boy up! 8-10 hrs for the swap, complete, if you use the 16v trans as well (recommended, as it is geared to take full advantage of the 16v's torque and hp..)
87 Cabby is CIS, 2.0L 16v is CIS Motronic.. swap the entire harness over.. still, it's an easy process.. shouldnt add much time to the swap.
Modified by qwikxr at 9:52 AM 9-22-2005
