1 - 5 of 5 Posts
After a recent foray to my dealer for the factory heater core feed hose, it seems as though VW lists the 8v/g60 hose for the 16v. The one problem is that this hose hits the distributor, but after reading the PN off my old one it comes back to the same 8v hose! It seems as thought VW has changed all the A2 heater core hoses over to the 8v style, which doesn't work on 16v's.
Re: 16v coolant hose help needed. (130_R)
Is there anything fancy about that hose? Is it the one that goes through the firewall? If so, I replaced mine with plain old heater hose from an auto parts store.
Re: (130_R)
There are two hoses coming in and out the firewall, which one are you replacing? I need to replace the one on the right(closer to the passenger side). Do you know the part number? Where you ordered yours?
thanks!
1 - 5 of 5 Posts
