1 - 5 of 5 Posts
i used the whole wiring harness of a 1992 passat and the and put it to my stock fuse block. the problem is that the car will start but will not rev up. revs a bit then it stops die for a sec and then revs up a bit. Does any one know the problem?
Re: 16v motor swap in to a1 running problem (orange_rabbit82)
Before you do anything, check all of your grounds. Bad or missing grounds has caused many a 16v to not run right.
Then, when you have checked them, go back and do it again.
Re: 16v motor swap in to a1 running problem (Gregor413)
Little off topic here but would you care to elaborate on how you spliced in the Passat wiring to the A1 fuse block? I'm in the middle of the same project and am looking for ideas.
Feel free to email me.
Thanks!
1 - 5 of 5 Posts
