Pin 10 on the knock box goes to the fuel pump relay in the Bentley schematics for an 87 GTI. The negative side of the coil on the 83 GTI goes to the fuel pump relay according to Bentley. Seems to me I should hook up pin 10 to the negative side of the coil. However I found this schematic on the web:
It shows pin 10 going to 50 which is the hot start pulse relay in the 83 GTI.
So which is it? Hot start relay or negaitive side of the coil? Or neither?
Thanks for any input.
