1 - 4 of 4 Posts
Ok i have searched and didnt find anything. and i didnt get much help in swap or scirocco forums
Its an 88 rocco, engine bay started on fire P.O. changed everything to 82 rocco, front to rear wiring engine and all. Now im changing the engine wiring back to a 16v.
I have changed ICU, knock sensor control, comp, coil, tested everything im getting power everywhere and have all the grounds still NO SPARK
give me some ideas i want to get it going again
[Modified by 80vwpickup, 4:42 PM 4-22-2003]
Discussion Starter · #2 ·
Re: 16v swap NEED HELP (80vwpickup)
come on i know plenty of you have swapped in a 16v what could i have forgot to do or done wrong?
well i decided it was time for another bump and
I can jump the fuel pump relay and it wont go on ,if thats any help
is there something that im unaware of that i have to wire to the fuse box or something come on
Re: 16v swap NEED HELP (16valvedCaddy)
yeah i figured it out I didnt have power to ecu, I tapped into the wire from TB to ecu, and now it works, thanks though
1 - 4 of 4 Posts
