got my 16vT up and running again, with the new block, SNS chip, lime top injectors (42) and bbm fuel rail..
but this time, i cant seem to find any power at all. i almost got creamed merging onto the freeway today
it sputters when i give it the tiniest bit of gas when cruising, and it just leaks boost when boost is supplied....
i thought it was the middle intake manifold gasket, because i had re-used it, but it seems that it isnt now. same problems.
i put the lower belt cover on today, and lined up all of my timing marks before firing up ( crank dampner, cam gear )
it doesnt idle with the distributor clocked in the middle, it has to be advanced (turned clockwise) all the way for it to idle smoothly
anyone got any suggestions?
