1 - 11 of 11 Posts
thank you in advance for your posts ....i just got my b5.5 wagon and i'm getting 18's....probably rh topline aa............i'd like to get prokit or a cupkit coilovers are to $$$$ what do you run?
Re: 18x8.5 with 235/40 susp? (hv3apbt)
I suggest you run a 225/40/18 size tire, 235 is too much especially for the front fenders. How low do you plan to go?
-Danny
Re: 18x8.5 with 235/40 susp? (97VenomGTI)
-Danny[HR][/HR]​
not really too much, im running 235/40/18 and my car is lowered about 2.25" up front. it does fine.
here's a picture..sorry it isnt a wagon tho.
suspension is h&R sports and neuspeed spec bilsteins set on the last notch up front.
Re: 18x8.5 with 235/40 susp? (schmove)
It makes realy big difference, what is tire manufacturer. Some 225/ tires can be actuality 235/ wide. :confused...:
[Modified by Ville, 11:19 PM 6-1-2002]
Re: 18x8.5 with 235/40 susp? (Ville)
quote:[HR][/HR]It makes realy big difference, what is tire manufacturer. Some 225/ tires can be actuality 235/ wide. :confused...:
[Modified by Ville, 11:19 PM 6-1-2002][HR][/HR]​
very true. the tire design can also make a difference in the overall width of the tire. some manufacturers are a bit thicker than others
Discussion Starter · #8 ·
guys...thank you for your replies.....i don't want to go much further than 2" in the front and 1 3/4" in the rear..maybe 2" in rear......schmove.....i checked your sig and have seen your car pics before i think that side view is perfect....the RH wheels have a little lip but and the wheel face will look good tucked back 1.5 "
I'd really suggest you go coil overs...you can lower car without going to really stiff springs like you have to when using stock strut housings. Those 40 series...bet the're ZR speed rated too will be hard as hell. How do you get away with that in the snow belt where the roads are like a war zone?
Discussion Starter · #11 ·
Re: 18x8.5 with 235/40 susp? (spitpilot)
thats what the factory alloys are for ...hehehe....i'm not that concerned with it.... i tend to be very careful in my travels.....
1 - 11 of 11 Posts
