GTI rack was all AL, and afaik no other model got that. Same D rack bushing is used on both sides. Other than that, it’ll work fine. I’m guessing you reused the bushings, otherwise you may have ordered the wrong ones, if sold in a kit.
Only mentioned the heater valve, because I’m 99% sure every Rabbit I’ve ever owned, had it at the top.
Switch harness would only be 2 female disconnects, but if you can get the correct connector, why not? It’s not polarized.
I zoomed in and definitely don’t see the tube. You have a plug in the hole the tube would poke through. That tube uses a specific grommet, if it matters to you.
You have a German pedal cluster on the way? It likely won’t be a direct fit, although I’ve made them work, in a Westy.
-Todd
-Todd
