If the hole is on the fender, you can remove the fender and patch it with a scrap of steel and a MIG. If it's on the cowl, there's often rust inside into the A-pillar and the windshield channel, and a proper repair may necessitate removing the windshield, and finding a replacement if you crack the old one is sometimes a challenge.
The steering column's lower bearing is held by a plastic cage that crumbles in time, and the fixes have been well-described: anything from a hose clamp on the steering shaft to a new bearing assembly, depending on how much work you're willing to do and how much shaming you can endure...
IDK how much an automatic with a rust hole could fetch compared to a GTI or a Caddy, but $2k is very well-bought and IMO it's worth not beating the thing into the ground (not saying that was the plan).
Welcome to The Nuthouse
