Hey guys! I’m pretty new to the forum. I recently picked up my first Scirocco. After a few days, I was driving back to work from lunch and it started sputtering, lurching, and lost most of its power. I pulled over to see if it was smoking anywhere and then was able to lurch it in 1st and 2nd to a parking lot where she still resides lol. Originally when the problem happened, it would at least start up but would not run smooth ( almost sounded like a misfire). Me and my buddy spent the night trying to diagnose the issue. We checked to make sure fuel was getting to the engine, nothing out of the injectors. so we traced it back to the fuel distributor, took it apart and cleaned it. Now i have at least some fuel out of the distributor but it still won’t start. I’ve checked the battery, spark plugs (even replaced them just in case) cleaned off the distributor and distributor cap, and also cleaned off any corrosion on the wireset from the coil all the way to the distributor. She still will only turn over. Could it be a grounding issue? compression? something as simple as carbon build up in the cylinder ? Any help is appreciated !! Just need some outside opinions
