I am working on a 1993 cabriolet automatic that is not getting voltage to the starter. I've narrowed this down to a specific relay under the dash but I cannot find any information about it to order a new one. I am not near the car so unfortunately I cannot look for part numbers.
I believe it would be called a starter relay or an ignition relay. I pulled it apart and diagnosed a bad component on it, (it looks like a small piece of red glass with what looks like a bit of solder in the middle, maybe a fuse) and when i jump this component the relay works and should theoretically start the car (the starter is out but it's now getting voltage). It is a 2-stage relay which seems to depend on both the ignition being in the start position as well as the transmission being in park or neutral. I'd love to be able to put a new part in so that I'm not risking a fire or damaging anything. The only marking I remember from the relay is on the top there was "92". It was in a separate location than the relay cluster, under the dash closer to the ignition switch along with one other relay. The wiring is larger gauge and goes directly to the solenoid.
Anyone know what this is and where I can get one?
Thanks!
Jon
Thanks!
Jon
