1 - 4 of 4 Posts
So ive taken apart the majority of the head unit on my 1993 Passat maked "VW
Premium Audio" trying to get the face off so I can fix the stop/eject
button. The thing is is that there seems to be some sort of retention
mechanism at the volume knob that i cant figure out how to get it apart.
Does anyone know how to get the face off such a unit? Thanks.
Re: 1993 Passat "Premium Audio" (96passatowner)
I've removed the face from the radio on my 91. To get the volume nob off, simply pull it up so that the shaft is exposed then get a little flat head driver in there and twist it to pop off the nob.
As far as lamps go, they're a bugger to change. Simple little bulbs with wires attached directly to wires! You'll need to snip the wire and re-solder the new one in. A pain yes, but a good opportunity to replace with red LED's to make a MK4 appearance!
1 - 4 of 4 Posts
