Does this car have prgrammable door locks? If so, what triggers them? Do the front doors automatically unlock if they are locked and you pull on the interior handle? Does the car have a remote keyless entry system? If so, How do you program it?
Quote, originally posted by jacksquat » |
Does this car have prgrammable door locks? |
Do the front doors automatically unlock if they are locked and you pull on the interior handle? |
Quote » |
Does the car have a remote keyless entry system? |
Quote » |
If so, How do you program it? |
Quote, originally posted by golfSPORT95 » |
Programming Keyless Entry Remotes 1. Put your spare key into the ignition and put it onto the ON position, DONT start the car 2. Close your door. In the drivers side, turn the key to the left (unlock position) and hold it. 3. It will beep 3 times. Let go to the key so it sits in the lock. 4. With each of your new remotes, separately, press the unlock button, each button will cause a "HONK" 5. Turn the key to the left again until it beeps. 6. PROGRAMMED keyless entry information: http://www.geocities.com/golfsport95/keyless_entry_FAQ.htm |
