so i took my 1999 a6 to the ac shop because it was blowing cold then abrubtly stopped. The ac shop said the freon was full and i most likley needed a compressor. why do they always go right to the compressor. i do need to install my new raidator and alternator but dont want to take off the front end and need to again for my ac. I also dont want to spend 400 bucks on a ac system i dont need. i had a code on vcds for flap malfuncion. i cleared it and didnt save it because im not smart enough to. the code hasnt came back and i am not sure what flap it was (if i would have saved the code i could have tested that one and not every one) tomorrow i will check if the compressor is actcualy spinning not just on the barring. but vcds shows the compressor when i turn it off and on. it also dosent throw a code i think it was 3 if its bad or somethig (i cant recall the exact prosses but i was reading the information wile i tested.
Chassis Type: 4B - Audi A6/S6/RS6/allroad C5 (1998 > 2005)
Scan: 01 02 03 06 08 15 16 17 18 22 34 35 36 37 45 55 56 57 65 67
75 76 77
Mileage: 292750km-181906miles
Address 01: Engine Labels: 078-907-551-AHA.lbl
Part No: 4D0 907 551 AH
Component: 2.8L V6/5V MOTR AT D02
Coding: 06252
Shop #: WSC 02325
VCID: 6C81C336EF9F4C3B43B-4B1E
No fault code found.
Readiness: 0110 1101
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 4B0 927 156 G
Component: AG5 01V 2.8l5V USA 8509
Coding: 00000
Shop #: WSC 00000
VCID: 2B03002A2A118B030A1-4B1E
1 Fault Found:
00526 - Brake Light Switch (F)
27-00 - Implausible Signal
Address 03: ABS Brakes Labels: 8E0-614-111-EDS.lbl
Part No: 8E0 614 111 A
Component: ABS/EDS 5.3 QUATTRO D10
Shop #: BB 24334
VCID: 1C61D3F67FBF7CBB73B-51F2
Address 08: Auto HVAC Labels: 4B0-820-043-MY1.lbl
Part No: 4B0 820 043 G
Component: A6-Klimavollautomat D55
Coding: 00160
Shop #: WSC 02325
VCID: 1E65D9FE69A36EAB9DF-25A6
Address 15: Airbags Labels: 4B0-959-655-AI7.lbl
Part No: 4B0 959 655 K
Component: Airbag 7 Audi 0501
Coding: 00106
Shop #: WSC 02314
VCID: 38292F66EB47309B773-5118
Address 17: Instruments Labels: 4B0-919-xxx-17.lbl
Part No: 4B0 919 930 RX
Component: C5-KOMBIINSTR. VDO D15
Coding: 07262
Shop #: WSC 42631
VCID: 0F7BB4BABE49D723069-513C
Address 35: Centr. Locks Labels:. 4B0-962-258.clb
Part No: 4B0 962 258 C
Component: Central Lock/Alarm D30
Coding: 15743
Shop #: WSC 02325
VCID: 290FFA2220ED9913F8D-4F0C
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00002
Shop #: WSC 26097
VCID: 6099A7061357185BEF3-4B00
End----------(Elapsed Time: 05:22, VBatt start/end: 12.5V/12.3V)-----------
75 76 77
Coding: 06252
Shop #: WSC 02325
Coding: 00000
Shop #: WSC 00000
1 Fault Found:
Shop #: BB 24334
Coding: 00160
Shop #: WSC 02325
Coding: 00106
Shop #: WSC 02314
Coding: 07262
Shop #: WSC 42631
Coding: 15743
Shop #: WSC 02325
Coding: 00002
Shop #: WSC 26097
