1 - 20 of 20 Posts
Hey guys,...my engine builder needs the following specs,....does anybody have them handy?
Engine is a stock 2.0 bottom, and Kent 258 cams. I cant find any info at all for the cams online, does anybody have the test article from the magazine? Maybe its in there? Thanks....
Cylinder Bore Size..... =
Crankshaft Stroke...... =
Connecting Rod length.. =
Number of Cylinders.... =
Engine RPM at Peak HP.. =
Compression Ratio...... =
Intake Valve Size...... =
Intake Valve Stem Size =
Max. Intake Valve Lift =
Intake Duration @ .050 =
Degreed Int. CenterLine =
Camshaft Lobe Centers.. =
Exhaust Valve Size..... =
Exhaust Valve Stem Size =
Max. Exhaust Valve Lift =
Exhaust Duration @ .050 =
Re: 2.0 16v detailed engine specs needed for my engine builder. (PowerDubs)
Cylinder Bore Size..... =82.5mm
Crankshaft Stroke...... =92.8mm
Number of Cylinders.... =6
Engine RPM at Peak HP.. =about 6500
Compression Ratio...... =10.7:1
Intake Valve Size...... =32mm
Intake Valve Stem Size =7mm
lenty more than Kent 258s
Exhaust Valve Size..... =28mm
Discussion Starter · #6 ·
Re: 2.0 16v detailed engine specs needed for my engine builder. (vwsnoop)
quote:[HR][/HR]
check the bentley book for correct specs.[HR][/HR]​
I would....if I was at the garage, and not at work.
Anybody????
Re: 2.0 16v detailed engine specs needed for my engine builder. (art.clemens)
Number of Cylinders.... =4
Compression Ratio...... =10.4:1
Max. Intake Valve Lift : a lot
Intake Duration @ .050 =check eurosport's website
Degreed Int. CenterLine =Check eurosport's website
Camshaft Lobe Centers.. =Check eurosport's website
Re: 2.0 16v detailed engine specs needed for my engine builder. (TheSaint)
Exhaust Duration @ .050 =[HR][/HR]​
rods are 144mm, comp is advertised at 10.8 but measures ~10.4:1, exhaust stems are 7mm also, inlet lift is .350", exhaust is .410" IIRC but if you are changing cams it does not matter.
Discussion Starter · #9 ·
Re: 2.0 16v detailed engine specs needed for my engine builder. (vwpat)
Ok guys....thanks for the help,..so far so good...
How about specs for the stock cams
then euro intake cam?
I'll keep digging for the Kent specs...
I know the stock cams list max HP at 5800rpms...
Discussion Starter · #11 ·
Thanks.
Now, I know the stock cams were listed at 5800 for max HP
What is the official rpm for max power on the euro intake...
Also, does anybody have the mag test of the Kent 258s and know what the RPM for max HP is on them?
Hopefully I can post good info off of these numbers... I am still working on my custom intake manifold, as the 50mm is far from ideal for top end perfomance...the plenum is too small and the runners are too long...
Discussion Starter · #13 ·
Re: 2.0 16v detailed engine specs needed for my engine builder. (jassem99)
quote:[HR][/HR]"as the 50mm is far from ideal for top end"
You'll get a few arguments there. Unless top end is 9000 rpm...[HR][/HR]​
Actually, no arguement is possible....the plenum on the 50mm was designed for a 1.8L engine...it is smaller than the plenum on the 42mm which was designed for a 2L engine. Luckily I have both, and a excellent welding shop to switch my 42mm plenum onto my 50mm runners....
I am not saying to raise the powerband much, if at all.....but this WILL make the power stronger at its peak, even if the peak remains close to, or at where it is... I've been doing some research and talking to some people for about 6 months on this,...and I am almost ready to do it....
I am not saying to raise the powerband much, if at all.....but this WILL make the power stronger at its peak, even if the peak remains close to, or at where it is... I've been doing some research and talking to some people for about 6 months on this,...and I am almost ready to do it....[HR][/HR]​
all motor headaches....
Discussion Starter · #15 ·
Re: 2.0 16v detailed engine specs needed for my engine builder. (killa)
quote:[HR][/HR]all motor headaches....[HR][/HR]​
Yea....I'll admit watching my friends run like 12.1 is fun....but somebodys got to be different!
Im sick of hearing blow-off valves!!
Discussion Starter · #16 ·
Ok.....here is part of the info he has given to me so far.......I think alot of the numbers in the beginning are specs for a custom header designed for the engine. I gave him the engine specs for a stock 2.0 engine with a euro cam ( what I have now) plus I gave him the specs for the Kent 258's. Of course, being that this guy is a hardcore V8 engine builder,...he told me to get bigger cams!! Maybe eventually....I have other things I need to pay for first...
The important stuff (to me anyway) is the fact that he was able to give me numbers for intake length, since I will be able to adjust that when I swap the plenums anyway. I am pretty excited about this idea.
~~~"for 5800 RPMs ;
--- Engine Data Input --- --- Straight-Pipe Specs ---
Engine Bore size = 3.248 Pri.= 1.356 dia. x 35.8 to 38.3 length
Crankshaft Stroke = 3.654 2nd-Wave is at Critical Length = 35.9 long
Connecting Rod Length = 5.669 --- 2-Step Header Specs ---
Number of Cylinders = 4 1st = 1.356 dia. x 17.1 to 18.4 length
Engine RPM at Peak HP = 5800 2nd = 1.481 dia. x 18.7 to 19.9 length
Compression Ratio = 10.40:1 * May use 2nd-Best Wave Specs < 6000 rpm
Intake Valve Size = 1.260 --- 3-Step Header Specs ---
Intake Valve Stem-size = .276 1st = 1.231 dia. x 17.5 to 18.4 length
Max. Intake Valve Lift = 0.378 2nd = 1.356 dia. x 9.5 to 10.3 length
Intake Duration @.050 = 207 3rd = 1.481 dia. x 8.7 to 9.6 length
Degreed Int. Centerline= 107.00 * May use 2nd-Best Wave Specs < 6000 rpm
Camshaft Lobe Centers = 109.00 --- Header Collector Specs ---
Exhaust Valve Size = 1.102 Collector= 2.531 dia 20.9 to 25.9 length
Exhaust Valve Stem-size= .276 2nd-Best Wave Collector Length=10.5 - 13.0
Max. Exhaust Valve Lift= 0.402 --- Acoustical Tuning Specs ---
Exhaust Duration @.050 = 215 Best-Wave (-Neg.Press)= 4300 to 6100 rpms
Head's Exh-port length = 3.204 Bad-Wave (+Pos.Press)= 1630 to 3130 rpms
2nd-Wave HP Loss= 1.6 to 2.0 Acoustical Wave-Lag Degrees = 3.2 to 6.4
Crank Rod/Bore Rod/Crank Rotation Piston Cylinder Piston--CFM @ inch. H2O
Angle Angle Angle Time Sec Depth Vol. CCs FPM @105 @28
5 1.61 173.39 0.000287 0.0092 1.248 638.8 36.8 19.0
15 4.78 160.22 0.000862 0.0820 11.135 1883.1 108.3 56.0
30 9.27 140.73 0.001724 0.3189 43.292 3548.5 204.2 105.4
45 13.17 121.83 0.002586 0.6843 92.906 4817.3 277.2 143.1
60 16.21 103.79 0.003448 1.1388 154.614 5579.3 321.0 165.8
75 18.14 86.86 0.004310 1.6358 222.098 5806.3 334.1 172.5
80 18.50 81.50 0.004598 1.8028 244.776 5769.9 332.0 171.4
85 18.73 76.27 0.004885 1.9679 267.183 5682.5 327.0 168.8
90 18.80 71.20 0.005172 2.1295 289.123 5548.4 319.2 164.9
100 18.50 61.50 0.005747 2.4374 330.925 5158.3 296.8 153.3
105 18.14 56.86 0.006034 2.5815 350.501 4912.3 282.6 146.0
110 17.63 52.37 0.006322 2.7181 369.040 4639.1 266.9 137.8
120 16.21 43.79 0.006897 2.9658 402.670 4030.7 231.9 119.8
135 13.17 31.83 0.007759 3.2680 443.710 3029.2 174.3 90.0
150 9.27 20.73 0.008621 3.4833 472.937 1999.9 115.1 59.4
165 4.78 10.22 0.009483 3.6115 490.341 989.0 56.9 29.4
180 0.00 0.00 0.010345 3.6540 496.111 0.0 0.0 0.0
for 7000 RPMS ;
Engine Bore size = 3.248 Pri.= 1.534 dia. x 33.4 to 35.9 length
Number of Cylinders = 4 1st = 1.534 dia. x 16.0 to 17.2 length
Engine RPM at Peak HP = 7000 2nd = 1.659 dia. x 17.4 to 18.7 length
Intake Valve Stem-size = .276 1st = 1.409 dia. x 16.4 to 17.2 length
Max. Intake Valve Lift = 0.378 2nd = 1.534 dia. x 8.9 to 9.7 length
Intake Duration @.050 = 207 3rd = 1.659 dia. x 8.1 to 9.0 length
Exhaust Valve Size = 1.102 Collector= 2.863 dia 16.4 to 21.4 length
Exhaust Valve Stem-size= .276 2nd-Best Wave Collector Length= 8.2 - 10.7
Exhaust Duration @.050 = 215 Best-Wave (-Neg.Press)= 5500 to 7300 rpms
Head's Exh-port length = 3.204 Bad-Wave (+Pos.Press)= 2295 to 3795 rpms
2nd-Wave HP Loss= 1.9 to 2.4 Acoustical Wave-Lag Degrees = 3.9 to 7.8
For 5800 RPMs = Total Intake System runner Length = 16.900" inches
For 7000 RPMs = Total Intake System runner Length = 14.000" inches
50mm runner diameter is plenty enough cross-sectional area to make peak HP
all the way to 7000 RPMs with right camshaft specs
your cam duration is on the small side
5800 RPM needs 230 duration @ .050"
7000 RPm mneeds 252 duration @ .050"
the larger plenum helps reduce reversion spikes , and also helps feed engine
at high RPMs "~~~~~
(I take it to mean this could help the idle problems with bigger cams by lessening the plate-pulse movement. Plus, he has agreed with me that while the 50mm runner themselves are a good upgrade, they are mismatched with the smaller plenum designed for the 1.8l engine which is causing a bottleneck. I find it amazing that in all the years of 16v tuning, I am the first to notice this, or at least realize it and do something about it.)
Discussion Starter · #18 ·
quote:[HR][/HR]Josh, i know u didnt think of that all by yourself
[HR][/HR]​
Which?
All that math mumbo-jumbo above came from an engine builder guy I know,....the idea to put the 42mm plenum onto the 50mm runners is all mine,...I thought about it last Dec when I was looking at a spare manifold I have. The engine builder guy just happens to agree with me about it. If you know anyone else who has actually done this already, what is his/her name, I would like to see what the results were.
Discussion Starter · #20 ·
I am not sure, as I havent taken any actual numbers...but it is very noticable by eye. I guess I could fill them both with liquid and measure once I cut them off...
I wasnt able to find any equations online either, except for a small blurb that mentioned that a plenum volume should be at least 80%? of a engines displacement.....or something like that...
Basically, it all boils down that the bigger engine will work better up high with a bigger plenum. Shouldnt cost TOO much to have done either... and I will measure intake tract length and adjust while I am at it also...
1 - 20 of 20 Posts
