1 - 3 of 3 Posts
Okay, i got my hands on a 2.0 16v motor for a project rocco. what is a great source for looking into the next step for preping the motor for the f/i b/4 it goes into the car. any info will be great. looking for the next step and am new to the home grown trubo set-ups but see its the only way to go.
Re: 2.0 16v turbo in an s2 (Johnzapp)
hey john, its brady. you can check out my setup at this link: http://www.sdsefi.com/features/aug01vw.htm
my longblock is completely stock except for a 3mm copper shim from gasketworks and 2 metal headgaskets. handles 10psi on pump gas and 15psi on c-16. you can check out the shim setup at http://www.headgasket.com
is this motor going into my old silver 8v scirocco?
also check out my partner's website: http://users.snip.net/~str8g/
AKA hardcorevw.com
theres 2 forums on there that deal with hi-po and turboed VW's.
whats are you plans exactly? EFI? low/high boost? junkyard parts?
[Modified by oversteervw, 4:24 PM 11-26-2001]
Whats up Brady? Thanks for the info. Yeah, I plan on doing a swap into your old rocco. I got my hands on a motor and want to get it right b/4 i put it in. I want to try to keep stock internals in the motor and run as much boost as possible.
Want to try to use as many used/junk yard parts that i can get my hands on.
Do you know anyone looking to part with any parts?
1 - 3 of 3 Posts
