Re: 2.0 cylinder head swap? (packrcch)
ALL mk4 2.0 engine heads are the same when it comes to port sizes and valve lift. There are minor differences in the camgears and other accessories but really not worth the trouble. There is no point to swap one stock 2.0 head for another.
If you want to make the 2.0 breathe better you have several options:
1. Camshaft with a higher lift and duration
2. Port and Polish
3. 1.8T head swap. The AEB head will bolt right up but you will need to replace the manifolds and the pistons/rods.
4. Go Forced Induction.
Finally, these kinds of topics are heavily discussed in the 2.0 technical forum. I strongly encourage you to use the SEARCH. Lots of good info comes out of there...
