hi, got an '04 2.0L golf iv 2.0 with 60000 mi. recently the shifter started vibrating while driving. it starts buzzing at about 2200 rpm, doesn't matter what gear or if the car is loaded or stationary in neutral. vibes worst in 1, 3, 5. it's annoying in 2, 4 but not as bad.
took the car to the dealer, they said they found the front exhaust hanger had come unwelded. they rewelded it but this didn't fix the problem. they say the vibrations must be normal then. (they're not.)
vibrations are worst when you actually rest your hand on the stick. if you barely touch it and don't push it against the gear box at all it doesn't vibe much. can you tighten it up so it doesn't push against the gear box?
