1 - 10 of 10 Posts
It's done, runs and drives. Stock dash and cluster. Custom A/C and power steering.
Discussion Starter #2
That looks very nicely done. What are you running for engine management? Even with stock boost it should plenty fun
Sent from my SM-S102DL using Tapatalk
Discussion Starter #4
Stock MED17 ECU and running 02A box with Wavetrac which it needs even with stock power.
Discussion Starter #5
Holy moly. That is one clean swap. Moar pics! Did you make brackets for the battery and air box?
Discussion Starter #9
Yes, I used the factory brackets from the Mk6 and modified them heavily to fit. Made custom front and rear mounts to sit the engine on a mk3 frame as I didn't want visible engine mounts in the bay.
Lots and lots of modification to make it all work.
1 - 10 of 10 Posts
