1 - 4 of 4 Posts
Someone here ever done it ?
I got '96 golf CL 1.8 mono-motronic, and I already have 2.0l ABA base and 2.0l cam in garage.
If I put higher fpr or adj. one, can I run 2.0l stroke base and 2.0l cam under 1.8 head with mono-injector and get no lean condition and no pinging ?
Can I expect 10-15hp and 10-15lbs/tq more of this small and easy setup ?
Thanx a lot guys !
Re: 2.0l base with 1.8 head (Belettte)
a lot of people have done the 2.0 litre block swap but i doubt too many people have done it with your injections system...at least in the states...the only 8v motor we got from 93-the present was a 2.0
since canada and europe got more engine choices that would be the place to look http://****************.com/smile/emthup.gif
10 HP sounds reasonable. Maybe 15-20 lbs more torque.
You shouldn't have to reconfigure your fuel injection just to make it work right. The injection system should be smart enough to deal with the extra demand on its own.
The injection system just sees the extra air demand and will meter fuel accordingly.
Discussion Starter · #4 ·
Re: 2.0l base with 1.8 head (der_panzer)
But it only have one injector... Enough to feed 2.0l stroke instead of 1.8 ? I don't think that mono-motronic has maf ?
Modified by Belettte at 5:40 PM 5-19-2004
1 - 4 of 4 Posts
