Re: 2.0T Hard Shift TSB (thomwagon)
The click happened to me three times when downshifting and it is more like a big BOOM. I also had/have the up shifting problems from 1 to 2 when the engine was cold.
I took the car to the dealer and showed told them about the TBS. They upgraded the software but did not replace the valve cover body.
Next I went back to the dealer and showed them the TBS where it says that the valve cover body needs to be replaced and the software upgraded.
The service manager told me that the technician did not read all the TBS.
He must have read it from the end to the beginning since the first line in the TBS for the solution to this problem states:
"Install an updated transmission valve body and update the transmission control module software." The service manager told that to all the cars with the similar problem they were upgraded the software only. However he said that he will order the part and will replace it. It is my understanding that replacing this part takes a lot of time and hard work.
Due to some other issues that I had with this dealer
http://(http://forums.vwvortex...1807) I am trying to get my car to a different dealer and have they fix all my problems.
Has anybody have a problem with the rear window wiper? Mine decided that is wiping clean the rear window is a hard work and this after replacing the blade.
Teo
