I added this onto a very old thread, but the forum warned me to start another thread, so this is it. I have a 2012 GTI and had the tensioner inspected during some routine maintenance at 65K miles.
Attached is a photo of the tensioner which my tech commented is quite far out. Interestingly my engine date code of 4/2012 was borderline, but I luckily have the newer model tensioner. However it appears I have a fair amount of timing chain stretch at low miles of "not crazy" driving. Attached is the photo and the Tech Tip. Comments on whether I need the chain(s) replaced urgently are welcome. The wording of the TSB about the "number of splines visible" is unclear to me, but another thread concludes it it actually the number of grooves to the right of the spring that should not be greater than 7. Is this correct?
Prior to the inspection, I assumed I would be fine up to at least 100K if I had the newer tensioner, but that was before I learned about the usually rapid rate of timing chain stretch in this engine.
I should get my OBD11 scanner in another day or two and will check the cam phase angle readings. Thanks.
