1 - 20 of 146 Posts
I have a 2005.5 MK5 Jetta. It has a grand total of 71k miles on it. The CEL recently came on, and through a P0016 error. Cam and Crank timing sensors reporting an error. I took it in. Well, the timing chain has totally worn down the gear on the intake cam shaft. The tensioner is all the way out, and the chain is stretched beyond use. This is screaming engineering fail. Has this happened to anyone else? I took it to a well respected local euro garage, and paid $3k to have them fix it. They replaced the timing chain, all of the guides, gaskets, chain, and gears. It runs like a champ now, but I shouldn't have had to drop $3k on a 5 year old car that has been impeccably cared for.
Would love to know if this is happening to anyone else, and if there is an active recall or case with VW, or class action suit starting. I want my $3k back.
That's very unfortunate. Me and my wife each own Jetta's. I had an '07 I just traded in for a TDI and her's is an '08 both with the 2.5L. We both put over 80K mi on our cars in less than two years, and I haven't noticed any sign of timing chain issues. I'd like to think the 2.5L is a solid engine, but it does sound like you may have ended up with a lemon for an engine. There is no reason why the timing chain should have catastrophically failed like that, short of bad maintenance. I certainly hope your rebuild lasts you much longer. Good Luck!
Yeah seems to be an increasingly common problem on the 05.5 and early 06 cars. You should call 1-800-822-8987 and politely explain your situation. You may qualify for at least a partial reimbursement since you're not that far out of warranty.
I have my Volkswagen service paper that my timing chain change at 104,000 mileage at VW dealership and it cost total $874.71 to get fix.
Discussion Starter · #6 ·
What all did they change out? For me, they had to replace the intake cam, the tensioners, the pulleys, the guides,. the gears, and the chain itself.
Did any of you that have had this problems notice anything prior to needed the repair? My car is a 06 with around 80k KM and I'm noticing my motor seems to make a ticking notice at idle...Sounds like a sewing machine. Wondering if this is a sign of bad things to come.
My chain skipped almost a year ago at 73k miles, all said and done it was $1600+ in diagnostics to find the cause, dealer quoted $3200 for timing chain replacement, so instead I got a motor off car-part.com and had a local shop install it. Cheaper to put in a motor with 35k than to rebuild part of one with almost 75k. VW Corporate essentially said they'd never heard of timing chain problems on the early MKV's and instead of any kind of break, they offered me $500 off a purchase of a new VW.
I also have to vouch for the 05.5-EARLY 06 chain failures. They redesigned them in 06 and again in 08 to prevent this.
I just had this happen recently, 2 days ago to be exact. I am wondering if I have a leg to stand on with VW. I mean it is about 10000km out of warranty, I bought it a year and a bit ago and this just happened. Is it worth complaining to vw about it and try to get them to do something being it seems this is a common theme of this engine? I think the worse part of all of this was when I bought this car I asked if there was any known issues with it, I guess a timing chain slip was considered a known issue then.
Anyways, is it just less expensive for a replacement engine? What should I be looking for from the mechanic doing the swap? Sorry I am so pissed and a noob with cars that I am at a loss what to do outside of taking a shot gun to the engine and say " Now it is dead".
This just happened to me. I have in being repaired at a local Euro garage with a quoted repair of $2,100.00. The problem is they don't know the extent of damage until they get into it so this could end up running closer to $3,000 all said and done.
I filed a complaint with VW customer service and they pretty much said too bad but we will give you a $1,000 towards a new car which I told them to shove it. I have just under 79,000 miles on the car. I am friends with an owner of the local VW dealership and they told me this is a known problem that is why the timing chain was re-designed in '06 and again in '08. VW will not admit to it though. I filed a complaint with the BBB and the NHTSA hoping maybe it will spur a recall. I think the more people putting in complaints VW will eventually have to acknowledge the issue. I too am extremely pissed now that I am reading that this is becoming more of a problem with these cars all hitting 60K-80K. I have always made sure I kept up on the maintenance and even kept records of everything. This should not be happening to a car with only 79K on it.
ANYONE THAT HAS HAD THIS PROBLEM PLEASE FILE A COMPLAINT WITH THE BBB AND NHTSA! THE MORE THE COMPLAINTS THEY GET THE BETTER CHANCE OF SOMETHING BEING DONE ABOUT IT.
Discussion Starter · #13 ·
Definitely call VW of America and report the issue. The more of us that report it, the better chance of a recall or a TSB or some slim chance we can get our money back.
I would take it to the dealer and get a quote. I found a local Euro Garage that has a stellar reputation that took care of mine. Cost me $3200 when all was said and done. A new motor from VW installed can be close to $5k.
Good luck.
Discussion Starter · #14 ·
irishman,
Where do you complain to the BBB and NHTSA? Is it an online form, or a phone #?
The BBB I did online. If you visit the website it is right on the home page. The NHTSA you can do online, I submitted mine over the phone. I don't know if anything will happen with this but I figure it can't hurt.
I just got the quote tonight from the garage it will be fixed at. He is putting in a 2008 engine with 80,000km on it for 2900 cdn. He will also be going over the timing chain and making sure it is perfect.
I am going to be bring the whole engine ( the mechanic even is allowing me to use his truck) to an authorized VW dealer, which is where I was told to bring the car after I had asked them 4 times what I should do and on the last return call told me to get the car to the shop. Hey morons, I need my car for work so the repairs had started. I informed them that the engine will be deliveried once out and if they do not accept it, I will be deliverying to VW canada's door and let them know how I feel about this bullet proof engine of theirs that is costing me so much. I bought this car for its high rating and till now a solid vehicle. If it wasn't for the the dealer I bought it from being so good to me and helping navigate the bs of vw, i would not own another one.
Funny thing about my call to vw today, after all that bs they still informed me about a minor recall on a wire harness for the airbag and asked when I would be bring it in to get looked at. Thanks for taking care of my main issue VW
Finkle56, file a complaint with the BBB and NHTSA, the more complaints they get the more pressure VW will get about doing something. Hey the worst nothing happens which is what is being done now, or they could end up covering the repair costs.
Extremely crappy deal man... Did you notice any warning signs before your motor went? How many KM on the car when it went? I only ask cause I'm sitting at 80km and I'm dreading this may happen to me.
The Check engine light came on and it had a rough start in the morning. It seemed like an ignition coil was going as I had the issue before. It ran normal after 15 seconds and that was it. That night engine was not starting at all. Saw the valves and they were bent in a nice c shape. So it went big but no real sign.
As for mileage, I had 153,000 km. I put 50,000 of that on myself but the rest was before. I bought it pre-loved as VW says. I guess pre loved means you better love your vw more. Get your timing chain inspected, it has no maintenance schedule so they may look at you funny but just say you have heard of it jumping. If they are any good they will look into it and inspect it. Funny that it isn't something that the 2.5 has for maintenance checking.
1 - 20 of 146 Posts
