From what I have read the TFSI crank needs machining to fit the VW iron block. Additionally, some say the clutch and flywheel would be different due to the bolt pattern of the flywheel being different too. Of the builds I've found not many are touching the cranks from TFSI motors.How much power can the stock crankshaft can hold I’ve been thinking about turbocharging my 2010 golf it has a stage 2 Integrated engineering kit on it already ive been looking at upgrade rods and pistons but I know the other weak point is the crankshaft and I was wondering if the tfsi crank is the same and if I could pull it off if the stock crank is weak I’m trying to get around 400hp at the wheels reliably
I've seen some chatter about the 150hp cranks being forged vs 170hp ones but I haven't seen any sources specifically.
As far as I can tell it's rods that are the limit but from people I've talked to as well, turbo sizing has a role in bottom end longevity and how the boost comes on and at what RPM. Sorry I don't have links to contribute to my claims.
400whp might be tough without doing some internal work. Only one way to find out!
Sent from my Pixel 4a using Tapatalk
