We haven't been having any problems with the car starting, but today my wife leaves Target, gets in the car, and it won't start.
I drove over there to check it out and here's everything I can think of to tell you:
- all electronics come on and work fine
- the gear display on the dash moves through the gears correctly while you're shifting
- with tranny in park, the key turns, but engine doesn't turn over
- checked all the fuses and they're fine
- locked and unlocked the doors with the physical key in the door (not using the remote entry) to ensure that the alarm wasn't stopping the car from starting
- battery is only about a year old
- you can turn the key past the "accesories on" stage as normal, it's just that nothing happens after you've done it.
I'm lost, and will probably have it towed to my shop tomorrow. But then, I found this site and did some searching and based on the responses I've seen to other questions it seems like you all may be able to give me some ideas
Any help would be appreciated!
Ron
Ron
