1 - 16 of 16 Posts
Sold sold sold sold sold sold sold sold sold!!!!!!!!!
$4000/OBO
this is a 2000 S4 w/ 182,XXX very clean car inside and out....cars front end an complete pass side was repainted back in FEB 2010
-heated polished side mirrors w/passenger side stubby view/blue tint
-seats are in good shape/Heated seats
-all weather floor mats/trunk floor mat also
-brakes & rotors are in good shape
-rs4 clutch replaced @ approx 155,XXXX (previous owner)
-stage 2 chip & tune performed by EPL in straford CT
-lowering springs
-neuspeed cat-back exhaust
-turbos are in good shape
-clean title
***CAR NEEDS THE FOLLOWING***
-ABS/module.... (ABS/BRAKE light is lit on cluster)
-AIRBAG light also is lit on cluster
-CHECK ENGINE light also lit on cluster (egt sensors)
-power steering rack is leaking
-rear axle seals are leaking
-needs motor mounts
-Tie rod ends
-alignment
-2x rear tires (bubble side walls)
-aux pump (leaking coolant)
heres a list i got from the shop when it was last serviced
INORDER TO GET YOUR CHECK ENGINE LIGHT OFF YOU WILL NEED TO REPLACE :
THE ABS CONTROL UNIT
EXHAUST GAS TEMPERATURE SENSORS
BOTH IGNITION CONTROL MODULES
FOR THE SUSPENSION,
YOU WOULD NEED TO REPLACE THE
TIE ROD ASSEMBLYS ON BOTH SIDES
AND ALL THE UPPER CONTROL ARMS
WITH A ALIGNMENT DUE TO THE FACT THAT WE WOULD BE REPLACING THE TIE RODS
NOW FOR SOME MISC. ITEMS
FOR THE COOLANT LEAK YOU WOULD NEED TO REPLACE SOME HOSE AND THE AUX. WATER PUMP.( THIS IS NOT YOUR MAIN WATER PUMP)
AXLE SEALS ARE LEAKING
REPLACE BROKEN MOTOR MOUNTS
as you can tell im very honest and upfront with the details of this car!!!! i consider the car as a project car an will take $$$ time and parts to get it running like new, but motor is very healthy w/ no oil issue an runs strong!!!!
reason for selling is my license has been suspending due to a DUI/reckless driving and ofcourse speeding an w/ the loss of my job i have to sacrifice one of my toys.....
i will sell as is and at best offer so shoot me a call/text: let me know what you will like to offer in cash or would like to trade me as far as a running vehicle thanks for looking.....
Car is located in Hamden CT 06514
203-654-5962
203-654-5962
203-654-5962
Gabe
Gabe
Gabe
Discussion Starter · #2 ·
Please reply thru text/call if serious, cars listed on other sites as well so would make it easier to reach me to whom ever is interested....thanks for looking
You think its just a waterpump issue? I dont want to get into something I have to rip the heads off of. Thanks Mike G
Discussion Starter · #7 ·
did you fix the overheating/miss fire issue?
Shop last told me to rePlace (auxiliary) pump which is common on these motors, Very small leak b/c I top off the plastic coolant tank bout every 2months, doesn't exactly over heat just that the fan continues to come on during traffic or driving around in the streets.... If interested an live close we can meet up I still drive the car here and there
1 - 16 of 16 Posts
