Year:2000
Make:Volkswagen
Model:Passat
Mileage:204000 M
Transmission:Manual
Engine:ATQ V6
Trim:GLS
For sale is a highly customized and recently serviced 2000 Passat V6 GLS 5-speed Wagon. The original engine suffered a timing chain tensioner failure and was replaced in August 2022. Service at that time included:
Spec stage I clutch, pressure plate, and dual-mass flywheel. All new bolts were used for the flywheel.
New timing chain tensioners (both sides) purchased from ECS Tuning.
All new cam seals, timing chain seals, and valve cover gaskets.
Complete Timing belt kit with Continental belt, Graf water pump, belt roller and tensioner roller, NTN Timing belt dampener and tensioning lever, Audi/VW thermostat, and Continental serpentine belt.
Air Filter and Oil Change with Liqui Moly 5w-40 LM20232
New group H7 battery
Two new flex pipes past the catalytic converters ($100 each)
Front right ABS sensor
All engine work was performed according to the Bentley manual precisely following torque specs
Upgrades and improvements to the car are as follows:
Thor aluminum skid plate
Passat W8 gauge cluster, interior lights, and sunroof control
Black, heated leather front seats
Heated Mirrors
Blaupunkt head unit with CD player and bluetooth aux adapter
ECU tuned by SpeedTuning USA
Hella Projector headlights w/ HIDS installed
Upgraded window motors to B5.5 version
Euroswitch
Previous maintenance:
New tires 10K ago
New front brake pads, rotors, and cylinders 3K ago
New hood strut
New alternator less than 10K ago
Additional Details:
The aforementioned service added up to over $1700 in parts alone. Heat and AC both work. The clear coat is peeling on the hood, roof, and rear bumper. No rust to be found. Current issues are as follows:
Headliner on sunroof is completely loose. Headliner is sagging in other spots and coming loose around the pillars a bit.
Airbag light is on, something to do with the passenger side collision sensor. I am actively looking for a new collision sensor to replace it with.
This is a great driving and riding car with all engine maintenance already done. No creaks, noises, or vibrations. Brakes great and has an impressive amount of power. Have made several out of town trips with it since repairs and will be daily driving it for the next few weeks. Feel free to message with any questions. 270-681-5024
Full Imgur Album
Automotive parking light Wheel Car Vehicle Tire
